  • 2 Vote(s) - 3 Average
Starter motor not turning engine
(23-08-2017, 02:17 PM)1938austin7 Wrote:
(21-08-2017, 09:38 PM)Louis Henry Wrote: I was astonished how much an earth strap from the starter to the body improved it.
Thanks all,
As it is out of the car I will do a test on the weekend and see if the gear is stuck.  Cheers Geoff
I tested it the other day with body of the starter resting on the battery and the gear flung out as far as it could.
Based on the earth comment, I am assuming corrosion on the battery terminal that I discovered when I dismantled the engine may have been enough to stop it working properly.
Fingers crossed.  I am hoping to get the car back on the road in the next couple of weeks.
Starter motor not turning engine - by 1938austin7 - 20-08-2017, 01:58 PM
RE: Starter motor not turning engine - by 1938austin7 - 23-10-2017, 10:23 AM
