Popping and not pulling well?
Your colder plug and presumably I cylinder to me indicates that it has an intermittent misfire. Check the ignition and plug in that cylinder if they are ok. Then check tappet clearances.
Also do a wet and dry compression test to check out valves and bore. I had this when a tappet came loose thus keeping a valve constantly closed.
John Mason.
RE: Popping and not pulling well? - by Timothy P - 11-04-2019, 05:21 PM
RE: Popping and not pulling well? - by Chris KC - 11-04-2019, 07:49 PM
RE: Popping and not pulling well? - by John Mason - 11-04-2019, 08:17 PM
RE: Popping and not pulling well? - by John Mason - 12-04-2019, 04:55 PM
RE: What have you done today with your Austin Seven - by John Mason - 10-04-2019, 04:51 PM
