Flywheel torque settinmg
Arnie, the flywheel is normally secured with a NUT. If you have a bolt then stop & think as it is a non-standard arrangement.
I'm not aware of any published torque for this joint, but it must be TIGHT. Most of us will use a long spanner or slip a bar over for extra leverage and heave as hard as we can. Lock the flywheel against the casing with a bar or bolt while you do this.
Flywheel torque settinmg - by SneezerUSA - 10-04-2019, 01:20 AM
RE: Flywheel torque settinmg - by AustinWood - 10-04-2019, 09:00 AM
RE: Flywheel torque settinmg - by John Mason - 10-04-2019, 09:05 AM
RE: Flywheel torque settinmg - by Chris KC - 10-04-2019, 09:05 AM
RE: Flywheel torque settinmg - by Terrytuned - 10-04-2019, 09:08 AM
RE: Flywheel torque settinmg - by AustinWood - 10-04-2019, 11:02 AM
RE: Flywheel torque settinmg - by David Stepney - 10-04-2019, 12:23 PM
RE: Flywheel torque settinmg - by Alan - 10-04-2019, 03:44 PM
RE: Flywheel torque setting - by SneezerUSA - 10-04-2019, 05:24 PM
RE: Flywheel torque settinmg - by David Witton - 10-04-2019, 06:25 PM
RE: Flywheel torque settinmg - by jansens - 10-04-2019, 07:20 PM
RE: Flywheel torque settinmg - by SneezerUSA - 10-04-2019, 08:53 PM
RE: Flywheel torque settinmg - by SneezerUSA - 11-04-2019, 11:58 AM
RE: Flywheel torque settinmg - by Rick F - 11-04-2019, 01:18 PM
RE: Flywheel torque settinmg - by Nick Turley - 12-04-2019, 05:01 PM
RE: Flywheel torque settinmg - by SneezerUSA - 27-04-2019, 10:28 PM
