Dynamo fuse?
Hello Bob
Many thanks for your input.
It was on the winter setting when things went wrong.
Firstly I noticed the light came on very brightly and when I looked at the ammeter
it wasn't showing any charge.
I switched it to the summer setting and back again but the bright light continued so
I returned it to the summer setting and left it there until I got home.
The first thing I did was check that the ignition light came on when I turned the ignition on,
which it did, and it was it's usual dim glow.
I then looked inside the cut-out, which has only done around a 1000 miles from new, and noticed the
small fuse was blown.
At this stage I decided to buy some new fuses and will then start checking other things.
I do know that I need to adjust the 3rd brush as it does charge at around 10 amps and has
consequently boiled some water out of the battery a couple of times in the past when I've forgotten to
switch it back to summer.
I normally only have it on winter mode for 5 minutes or so after I have used the starter, so
that it can replenish the battery a bit. Well that's my way of thinking anyhow.
I shall fit the fuses in the next couple of days when I have time and then do the usual checks on
the dynamo.
To be continued...
Graham
Dynamo fuse? - by Graham Honnor - 07-04-2019, 06:55 PM
RE: Dynamo fuse? - by David Stepney - 07-04-2019, 08:14 PM
RE: Dynamo fuse? - by Graham Honnor - 07-04-2019, 08:20 PM
RE: Dynamo fuse? - by daveg - 07-04-2019, 08:41 PM
RE: Dynamo fuse? - by Graham Honnor - 07-04-2019, 08:46 PM
RE: Dynamo fuse? - by David Stepney - 07-04-2019, 08:54 PM
RE: Dynamo fuse? - by Graham Honnor - 07-04-2019, 09:03 PM
RE: Dynamo fuse? - by David Stepney - 07-04-2019, 09:30 PM
RE: Dynamo fuse? - by Bob Culver - 07-04-2019, 10:11 PM
RE: Dynamo fuse? - by Graham Honnor - 08-04-2019, 04:29 PM
RE: Dynamo fuse? - by Bob Culver - 08-04-2019, 08:32 PM
RE: Dynamo fuse? - by Graham Honnor - 20-04-2019, 11:34 AM
RE: Dynamo fuse? - by Graham Honnor - 21-04-2019, 07:05 PM
RE: Dynamo fuse? - by Bob Culver - 21-04-2019, 10:46 PM
