08-04-2019, 10:24 AM
Fitting of the dynamo on a coil ignited engine should be straightforward. Depending on the spec of dynamo you may need to remove the long bolt from the mounting (the one by the front of the block), the dynamo should push into place easily, but put a squirt of oil on the gear to be kind to it. Two fixing bolts are easy to access, put the top one in first, but the one by the block just above the crankcase is best put in place before offering up the dynamo, and it is easiest to have a screwdriver slot in the head for tightening it. Good luck!
Robert Leigh
Robert Leigh
