1932\3 austin7 RP
(20-10-2017, 09:45 AM)Martin Prior Wrote:
(19-10-2017, 11:17 PM)Smiley Wrote: Hello Ian, The existing RP Box is worn and has been adjusted to take up the slack. This has produced tight spots.
The Ruby box appears to be in good condition and I was considering swopping the complete unit over. Is that possible?
Thanks
Smiley
Personally, I'd look around for a decent RP steering box.  Once you start fitting incorrect parts, one thing tends to lead to another. If you use the Ruby wheel, you'll then have the issue of losing your hand throttle and ignition timing levers, which will lead to further mods being needed, and so on ad infinitum!
Hello Martin, Thanks for advice.  I hadn't really thought about about problems at the top end.  I might decide to take austin Wood's advice and see if it possible to sort the problem by turning the worm wheel on the existing box to a new position.  Nothing to lose at this stage.  Thanks again.
1932\3 austin7 RP - by Smiley - 19-10-2017, 08:10 PM
RE: 1932\3 austin7 RP - by Ruairidh Dunford - 19-10-2017, 08:51 PM
RE: 1932\3 austin7 RP - by Smiley - 19-10-2017, 10:11 PM
RE: 1932\3 austin7 RP - by Ruairidh Dunford - 19-10-2017, 10:14 PM
RE: 1932\3 austin7 RP - by Smiley - 19-10-2017, 10:38 PM
RE: 1932\3 austin7 RP - by Ian Williams - 19-10-2017, 10:58 PM
RE: 1932\3 austin7 RP - by Smiley - 19-10-2017, 11:17 PM
RE: 1932\3 austin7 RP - by Martin Prior - 20-10-2017, 09:45 AM
RE: 1932\3 austin7 RP - by Smiley - 20-10-2017, 07:35 PM
RE: 1932\3 austin7 RP - by Ian Williams - 19-10-2017, 11:38 PM
RE: 1932\3 austin7 RP - by AustinWood - 20-10-2017, 12:11 PM
RE: 1932\3 austin7 RP - by Michael - 23-10-2017, 10:04 AM
RE: 1932\3 austin7 RP - by Steve Jones - 23-10-2017, 07:47 PM
RE: 1932\3 austin7 RP - by "Slack Alice" Simon - 23-10-2017, 03:46 PM
RE: 1932\3 austin7 RP - by Ian Williams - 23-10-2017, 07:02 PM
RE: 1932\3 austin7 RP - by Michael - 23-10-2017, 10:19 PM
