  • 1 Vote(s) - 4 Average
Crank end float
01-04-2019, 08:52 AM (This post was last modified: 01-04-2019, 08:57 AM by Tony Press.)
Being a Phoenix it is unlikely to have the ball and roller bearing at the front , so check the two angular contact ball bearings for correct assembly back to back or damage/wear. Also check if the angular contact bearings are the narrow outer ring type in a deep front housing.
Also if you cannot recognize an angular contact bearing you should trust any work to an experienced Austin 7 mechanic.
Crank end float - by brufsup - 31-03-2019, 10:14 PM
RE: Crank end float - by Chris KC - 31-03-2019, 10:22 PM
RE: Crank end float - by brufsup - 31-03-2019, 10:35 PM
RE: Crank end float - by Bob Culver - 31-03-2019, 10:50 PM
RE: Crank end float - by Tony Press - 31-03-2019, 10:52 PM
RE: Crank end float - by brufsup - 03-04-2019, 08:52 AM
RE: Crank end float - by Chris KC - 03-04-2019, 09:19 AM
RE: Crank end float - by Bob Culver - 03-04-2019, 09:45 AM
RE: Crank end float - by Chris KC - 03-04-2019, 10:29 AM
RE: Crank end float - by brufsup - 03-04-2019, 06:23 PM
RE: Crank end float - by "Slack Alice" Simon - 03-04-2019, 07:48 PM
RE: Crank end float - by Bob Culver - 03-04-2019, 08:19 PM
RE: Crank end float - by Tony Press - 03-04-2019, 10:39 PM
RE: Crank end float - by brufsup - 03-04-2019, 10:52 PM
RE: Crank end float - by Bob Culver - 03-04-2019, 11:23 PM
RE: Crank end float - by Chris KC - 04-04-2019, 07:39 AM
RE: Crank end float - by Charles P - 04-04-2019, 08:18 AM
RE: Crank end float - by brufsup - 04-04-2019, 08:37 AM
RE: Crank end float - by David Stepney - 04-04-2019, 09:03 AM
RE: Crank end float - by brufsup - 04-04-2019, 09:10 AM
RE: Crank end float - by Chris KC - 04-04-2019, 09:11 AM
RE: Crank end float - by brufsup - 04-04-2019, 09:45 AM
RE: Crank end float - by Tony Press - 04-04-2019, 10:28 PM
RE: Crank end float - by Bob Culver - 05-04-2019, 02:23 AM
RE: Crank end float - by brufsup - 05-04-2019, 09:17 AM
RE: Crank end float - by Terrytuned - 05-04-2019, 10:04 AM
RE: Crank end float - by Zetomagneto - 05-04-2019, 10:38 AM
RE: Crank end float - by brufsup - 09-04-2019, 08:28 AM
RE: Crank end float - by Bob Culver - 09-04-2019, 10:51 AM
