  • 1 Vote(s) - 4 Average
Crank end float
Just how critical the way around an unmatched ac pair is fitted is debatable.
Either the case has been machined wrong or narrow ac races have been fitted without spacers where wide should have been used. The crankcase number would be of interest
If been loose in the case should fall out.
The usual warning is to avoid breaking the lip, but this has already ben done and is now strong steel. Do not attempt to remove..
Crank end float - by brufsup - 31-03-2019, 10:14 PM
RE: Crank end float - by Chris KC - 31-03-2019, 10:22 PM
RE: Crank end float - by brufsup - 31-03-2019, 10:35 PM
RE: Crank end float - by Bob Culver - 31-03-2019, 10:50 PM
RE: Crank end float - by Tony Press - 31-03-2019, 10:52 PM
RE: Crank end float - by brufsup - 03-04-2019, 08:52 AM
RE: Crank end float - by Chris KC - 03-04-2019, 09:19 AM
RE: Crank end float - by Bob Culver - 03-04-2019, 09:45 AM
RE: Crank end float - by Chris KC - 03-04-2019, 10:29 AM
RE: Crank end float - by brufsup - 03-04-2019, 06:23 PM
RE: Crank end float - by "Slack Alice" Simon - 03-04-2019, 07:48 PM
RE: Crank end float - by Bob Culver - 03-04-2019, 08:19 PM
RE: Crank end float - by Tony Press - 03-04-2019, 10:39 PM
RE: Crank end float - by brufsup - 03-04-2019, 10:52 PM
RE: Crank end float - by Bob Culver - 03-04-2019, 11:23 PM
RE: Crank end float - by Chris KC - 04-04-2019, 07:39 AM
RE: Crank end float - by Charles P - 04-04-2019, 08:18 AM
RE: Crank end float - by brufsup - 04-04-2019, 08:37 AM
RE: Crank end float - by David Stepney - 04-04-2019, 09:03 AM
RE: Crank end float - by brufsup - 04-04-2019, 09:10 AM
RE: Crank end float - by Chris KC - 04-04-2019, 09:11 AM
RE: Crank end float - by brufsup - 04-04-2019, 09:45 AM
RE: Crank end float - by Tony Press - 04-04-2019, 10:28 PM
RE: Crank end float - by Bob Culver - 05-04-2019, 02:23 AM
RE: Crank end float - by brufsup - 05-04-2019, 09:17 AM
RE: Crank end float - by Terrytuned - 05-04-2019, 10:04 AM
RE: Crank end float - by Zetomagneto - 05-04-2019, 10:38 AM
RE: Crank end float - by brufsup - 09-04-2019, 08:28 AM
RE: Crank end float - by Bob Culver - 09-04-2019, 10:51 AM
