  • 1 Vote(s) - 4 Average
Crank end float
Does the front cover plate stand slightly proud of the crankcase? Can the shaft be seen to move relative bearing inner rings, or do outer rings move in crankcase? Even if back to front cf customary, unless the stepped type, ac races should have little movement. (sorry KC. Somehow I jumped past your post immediately above!)
Crank end float - by brufsup - 31-03-2019, 10:14 PM
RE: Crank end float - by Chris KC - 31-03-2019, 10:22 PM
RE: Crank end float - by brufsup - 31-03-2019, 10:35 PM
RE: Crank end float - by Bob Culver - 31-03-2019, 10:50 PM
RE: Crank end float - by Tony Press - 31-03-2019, 10:52 PM
RE: Crank end float - by brufsup - 03-04-2019, 08:52 AM
RE: Crank end float - by Chris KC - 03-04-2019, 09:19 AM
RE: Crank end float - by Bob Culver - 03-04-2019, 09:45 AM
RE: Crank end float - by Chris KC - 03-04-2019, 10:29 AM
RE: Crank end float - by brufsup - 03-04-2019, 06:23 PM
RE: Crank end float - by "Slack Alice" Simon - 03-04-2019, 07:48 PM
RE: Crank end float - by Bob Culver - 03-04-2019, 08:19 PM
RE: Crank end float - by Tony Press - 03-04-2019, 10:39 PM
RE: Crank end float - by brufsup - 03-04-2019, 10:52 PM
RE: Crank end float - by Bob Culver - 03-04-2019, 11:23 PM
RE: Crank end float - by Chris KC - 04-04-2019, 07:39 AM
RE: Crank end float - by Charles P - 04-04-2019, 08:18 AM
RE: Crank end float - by brufsup - 04-04-2019, 08:37 AM
RE: Crank end float - by David Stepney - 04-04-2019, 09:03 AM
RE: Crank end float - by brufsup - 04-04-2019, 09:10 AM
RE: Crank end float - by Chris KC - 04-04-2019, 09:11 AM
RE: Crank end float - by brufsup - 04-04-2019, 09:45 AM
RE: Crank end float - by Tony Press - 04-04-2019, 10:28 PM
RE: Crank end float - by Bob Culver - 05-04-2019, 02:23 AM
RE: Crank end float - by brufsup - 05-04-2019, 09:17 AM
RE: Crank end float - by Terrytuned - 05-04-2019, 10:04 AM
RE: Crank end float - by Zetomagneto - 05-04-2019, 10:38 AM
RE: Crank end float - by brufsup - 09-04-2019, 08:28 AM
RE: Crank end float - by Bob Culver - 09-04-2019, 10:51 AM
