02-04-2019, 10:34 PM
John,
The speedi sleeve does not go on the crankshaft !!!
The oil seal runs on the flywheel boss which is rough turned which will ruin a lip seal.
Lip seals are designed to run on a ground shaft.
The speedi seal goes on the flywheel boss to give a smooth surface for the lip seal.
The crankshaft remains unaltered so everything will fit as normal.
SKF do not have a page for A7 owners.
Hope this clarifies things a bit.
Cheers Dickie
Cheers Dickie
