charging question.
#32
10 hours ago
SUCCESS!!!!
I had been worried that the spring was unsuitable. It was far to weak and had been soldered at one end ( I presume to stop it falling off!)   I have replaced it with a slightly heavier one and it works perfectly. It is not too strong to affect the contacts from closing but assists the reverse current to allow opening at a normal tick over.
31-03-2019, 11:21 AM
Ray,
"If the cut out points are not separating when the voltage is reduced what can I do to fix it please?"
My electrical knowledge is sketchy but from earlier discussions the cut out spring may have lost a little tension - it is possible to increase the spring tension by slightly bending down the bottom bracket ?
Tony.
Always look for the simple solution.
charging question. - by Ray White - 29-03-2019, 09:21 PM
RE: charging question. - by John Mason - 29-03-2019, 09:55 PM
RE: charging question. - by bob46320 - 29-03-2019, 10:07 PM
RE: charging question. - by Ray White - 30-03-2019, 12:24 AM
RE: charging question. - by Bob Culver - 30-03-2019, 01:30 AM
RE: charging question. - by Ray White - 30-03-2019, 05:28 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 08:18 PM
RE: charging question. - by Bob Culver - 30-03-2019, 08:42 PM
RE: charging question. - by Ray White - 30-03-2019, 09:32 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 10:24 PM
RE: charging question. - by Ray White - 30-03-2019, 11:30 PM
RE: charging question. - by Tony Press - 31-03-2019, 01:21 AM
RE: charging question. - by bob46320 - 31-03-2019, 07:21 AM
RE: charging question. - by Bob Culver - 31-03-2019, 07:39 AM
RE: charging question. - by Ray White - 31-03-2019, 08:54 AM
RE: charging question. - by Ray White - 31-03-2019, 10:09 AM
RE: charging question. - by Ray White - 31-03-2019, 03:24 PM
RE: charging question. - by Bob Culver - 31-03-2019, 07:53 PM
RE: charging question. - by Ray White - 31-03-2019, 09:20 PM
RE: charging question. - by Bob Culver - 31-03-2019, 11:03 PM
RE: charging question. - by Ray White - 31-03-2019, 11:37 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:18 AM
RE: charging question. - by Ray White - 01-04-2019, 12:37 AM
RE: charging question. - by David Stepney - 01-04-2019, 01:07 AM
RE: charging question. - by Ray White - 01-04-2019, 08:40 AM
RE: charging question. - by David Stepney - 01-04-2019, 09:25 AM
RE: charging question. - by Ray White - 01-04-2019, 09:58 AM
RE: charging question. - by Ray White - 01-04-2019, 12:23 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:30 PM
RE: charging question. - by Ray White - 01-04-2019, 12:50 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:57 PM
RE: charging question. - by Tony Press - 01-04-2019, 10:24 PM
RE: charging question. - by Ray White - 02-04-2019, 12:07 AM
RE: charging question. - by Tony Press - 02-04-2019, 12:14 AM
RE: charging question. - by Bob Culver - 02-04-2019, 12:30 AM
RE: charging question. - by Ray White - 03-04-2019, 03:24 PM
