01-04-2019, 08:13 PM
HI RPM,
Personally I would remove the whole steering column and machine off the weld making sure Not to damage the Splines,
Then with the extension removed you will know if the thread has been damaged and carefully cleanup the spline .
If that approach not successful the next option Cut off damaged section and Use the Extension Piece to replace damagedĀ shaft back to the length required
Colin
NZ
Colin
NZ
