King Pins
I did see once on an early car ,a 5/16 BSF pipe silver soldered through the brass cap on the stub axel . On the top of the pipe a small  grease nipple was attached. this enabled the top bush to be greased in the normal  way and the bottom bush greased through the hollow centre of the king pin  via the 5/16 BSF tapped hole in the top. This was done I think to be able to get more pressure to the bottom bush.
King Pins - by rubyman - 31-03-2019, 11:25 AM
RE: King Pins - by squeak - 31-03-2019, 12:37 PM
RE: King Pins - by Chris KC - 31-03-2019, 12:41 PM
RE: King Pins - by Howard Wright - 31-03-2019, 04:11 PM
RE: King Pins - by "Slack Alice" Simon - 31-03-2019, 05:28 PM
RE: King Pins - by Ken Morton - 31-03-2019, 06:58 PM
RE: King Pins - by Bob Culver - 31-03-2019, 07:37 PM
RE: King Pins - by AustinWood - 31-03-2019, 11:06 PM
RE: King Pins - by David Stepney - 01-04-2019, 12:23 AM
