Torque for axle banjo and torque tube bolts
Axle =1938/39 (heavy). Bolts = Stainless (A2 - 70) 5/16 BSF cut to length so full thread engagement in banjo halves and torque tube to banjo without bottoming.  Using NORD-LOCK lock washers.  Threads smeared with copaslip to avoid axle thread corrosion and galling of stainless thread with steel casing.
What is a good torque wrench setting to use??  I have seen that 22Nm (16.2 ftlbs) is max for the 5/16 A2-70. (But note NORD-LOCK washers)
Dennis
Torque for axle banjo and torque tube bolts - by Dennis Nicholas - 19-10-2017, 06:49 PM
