charging question.
I suppose the battery terminals are clean ? If they are heavily oxidised between the lead post and the brass battery clamps, they can act as a sort of diode causing all sorts of low current problems. Ie - you can get current out for lights and starting etc, but more difficult to get stuff back into the battery.
Also, on my ignition light, there is some cotton covered resistance wire wrapped around the bulb holder - I guess to put some parallel resistance across the ignition light circuit. If that were damaged, would it make a difference ??
charging question. - by Ray White - 29-03-2019, 09:21 PM
RE: charging question. - by John Mason - 29-03-2019, 09:55 PM
RE: charging question. - by bob46320 - 29-03-2019, 10:07 PM
RE: charging question. - by Ray White - 30-03-2019, 12:24 AM
RE: charging question. - by Bob Culver - 30-03-2019, 01:30 AM
RE: charging question. - by Ray White - 30-03-2019, 05:28 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 08:18 PM
RE: charging question. - by Bob Culver - 30-03-2019, 08:42 PM
RE: charging question. - by Ray White - 30-03-2019, 09:32 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 10:24 PM
RE: charging question. - by Ray White - 30-03-2019, 11:30 PM
RE: charging question. - by Tony Press - 31-03-2019, 01:21 AM
RE: charging question. - by bob46320 - 31-03-2019, 07:21 AM
RE: charging question. - by Bob Culver - 31-03-2019, 07:39 AM
RE: charging question. - by Ray White - 31-03-2019, 08:54 AM
RE: charging question. - by Ray White - 31-03-2019, 10:09 AM
RE: charging question. - by Ray White - 31-03-2019, 03:24 PM
RE: charging question. - by Bob Culver - 31-03-2019, 07:53 PM
RE: charging question. - by Ray White - 31-03-2019, 09:20 PM
RE: charging question. - by Bob Culver - 31-03-2019, 11:03 PM
RE: charging question. - by Ray White - 31-03-2019, 11:37 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:18 AM
RE: charging question. - by Ray White - 01-04-2019, 12:37 AM
RE: charging question. - by David Stepney - 01-04-2019, 01:07 AM
RE: charging question. - by Ray White - 01-04-2019, 08:40 AM
RE: charging question. - by David Stepney - 01-04-2019, 09:25 AM
RE: charging question. - by Ray White - 01-04-2019, 09:58 AM
RE: charging question. - by Ray White - 01-04-2019, 12:23 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:30 PM
RE: charging question. - by Ray White - 01-04-2019, 12:50 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:57 PM
RE: charging question. - by Tony Press - 01-04-2019, 10:24 PM
RE: charging question. - by Ray White - 02-04-2019, 12:07 AM
RE: charging question. - by Tony Press - 02-04-2019, 12:14 AM
RE: charging question. - by Bob Culver - 02-04-2019, 12:30 AM
RE: charging question. - by Ray White - 03-04-2019, 03:24 PM
