charging question.
There can’t be a problem with the ignition light. It is just a bulb wired between the battery and the dynamo which lights up when there is a difference in potential between them.
The symptoms you describe suggest that the contacts of the cut out are not being thrown apart as the voltage at the dynamo diminishes. I figured out what was going on once, but have subsequently forgotten.
Peter
ETA. Take a look at http://www.austin7.org/Technical%20Artic...refresher/
There are two coils in the cut out. Coil from D+ causes the cut out to be pulled in. Current then flows through the points from D+ to A charging the battery. A second coil in the path between the points and A will kick open the points if the current flow is reversed from A to D+.
charging question. - by Ray White - 29-03-2019, 09:21 PM
RE: charging question. - by John Mason - 29-03-2019, 09:55 PM
RE: charging question. - by bob46320 - 29-03-2019, 10:07 PM
RE: charging question. - by Ray White - 30-03-2019, 12:24 AM
RE: charging question. - by Bob Culver - 30-03-2019, 01:30 AM
RE: charging question. - by Ray White - 30-03-2019, 05:28 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 08:18 PM
RE: charging question. - by Bob Culver - 30-03-2019, 08:42 PM
RE: charging question. - by Ray White - 30-03-2019, 09:32 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 10:24 PM
RE: charging question. - by Ray White - 30-03-2019, 11:30 PM
RE: charging question. - by Tony Press - 31-03-2019, 01:21 AM
RE: charging question. - by bob46320 - 31-03-2019, 07:21 AM
RE: charging question. - by Bob Culver - 31-03-2019, 07:39 AM
RE: charging question. - by Ray White - 31-03-2019, 08:54 AM
RE: charging question. - by Ray White - 31-03-2019, 10:09 AM
RE: charging question. - by Ray White - 31-03-2019, 03:24 PM
RE: charging question. - by Bob Culver - 31-03-2019, 07:53 PM
RE: charging question. - by Ray White - 31-03-2019, 09:20 PM
RE: charging question. - by Bob Culver - 31-03-2019, 11:03 PM
RE: charging question. - by Ray White - 31-03-2019, 11:37 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:18 AM
RE: charging question. - by Ray White - 01-04-2019, 12:37 AM
RE: charging question. - by David Stepney - 01-04-2019, 01:07 AM
RE: charging question. - by Ray White - 01-04-2019, 08:40 AM
RE: charging question. - by David Stepney - 01-04-2019, 09:25 AM
RE: charging question. - by Ray White - 01-04-2019, 09:58 AM
RE: charging question. - by Ray White - 01-04-2019, 12:23 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:30 PM
RE: charging question. - by Ray White - 01-04-2019, 12:50 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:57 PM
RE: charging question. - by Tony Press - 01-04-2019, 10:24 PM
RE: charging question. - by Ray White - 02-04-2019, 12:07 AM
RE: charging question. - by Tony Press - 02-04-2019, 12:14 AM
RE: charging question. - by Bob Culver - 02-04-2019, 12:30 AM
RE: charging question. - by Ray White - 03-04-2019, 03:24 PM
