charging question.
Today I had a chance to take a closer look at what is going on and the issue seems to be with the ignition warning light. When I switch on, the light comes on as normal. When I start the engine the ignition light remains on until I increase the revs and it goes out when the ammeter switches over to charge as normal.
The difference is that the light stays OFF as revs are reduced and doesn't come on again even when the ammeter shows discharge. If I turn the engine off and switch the ignition back on again, the light comes on again as normal.
All I have done so far is clean the cut out contacts with a piece of paper. The cut out points were just a little dirty but nothing to speak of.
charging question. - by Ray White - 29-03-2019, 09:21 PM
RE: charging question. - by John Mason - 29-03-2019, 09:55 PM
RE: charging question. - by bob46320 - 29-03-2019, 10:07 PM
RE: charging question. - by Ray White - 30-03-2019, 12:24 AM
RE: charging question. - by Bob Culver - 30-03-2019, 01:30 AM
RE: charging question. - by Ray White - 30-03-2019, 05:28 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 08:18 PM
RE: charging question. - by Bob Culver - 30-03-2019, 08:42 PM
RE: charging question. - by Ray White - 30-03-2019, 09:32 PM
RE: charging question. - by Peter Johnson - 30-03-2019, 10:24 PM
RE: charging question. - by Ray White - 30-03-2019, 11:30 PM
RE: charging question. - by Tony Press - 31-03-2019, 01:21 AM
RE: charging question. - by bob46320 - 31-03-2019, 07:21 AM
RE: charging question. - by Bob Culver - 31-03-2019, 07:39 AM
RE: charging question. - by Ray White - 31-03-2019, 08:54 AM
RE: charging question. - by Ray White - 31-03-2019, 10:09 AM
RE: charging question. - by Ray White - 31-03-2019, 03:24 PM
RE: charging question. - by Bob Culver - 31-03-2019, 07:53 PM
RE: charging question. - by Ray White - 31-03-2019, 09:20 PM
RE: charging question. - by Bob Culver - 31-03-2019, 11:03 PM
RE: charging question. - by Ray White - 31-03-2019, 11:37 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:18 AM
RE: charging question. - by Ray White - 01-04-2019, 12:37 AM
RE: charging question. - by David Stepney - 01-04-2019, 01:07 AM
RE: charging question. - by Ray White - 01-04-2019, 08:40 AM
RE: charging question. - by David Stepney - 01-04-2019, 09:25 AM
RE: charging question. - by Ray White - 01-04-2019, 09:58 AM
RE: charging question. - by Ray White - 01-04-2019, 12:23 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:30 PM
RE: charging question. - by Ray White - 01-04-2019, 12:50 PM
RE: charging question. - by David Stepney - 01-04-2019, 12:57 PM
RE: charging question. - by Tony Press - 01-04-2019, 10:24 PM
RE: charging question. - by Ray White - 02-04-2019, 12:07 AM
RE: charging question. - by Tony Press - 02-04-2019, 12:14 AM
RE: charging question. - by Bob Culver - 02-04-2019, 12:30 AM
RE: charging question. - by Ray White - 03-04-2019, 03:24 PM
