3 speed clutch pedal spring replacement
Jon the 3spd clutch pedal spring keeps the pedal in contact with the release bearing as the bearing is rotating all the time, it is not a pedal return spring if you have an original clutch release bearing. If a 4spd release bearing has been fitted then you need a return spring as the 4spd bearing only rotates when you engage the clutch.   Terry.
3 speed clutch pedal spring replacement - by JonE - 27-03-2019, 09:41 AM
RE: 3 speed clutch pedal spring replacement - by Terrytuned - 27-03-2019, 10:56 AM
