No (accu) spark - test sequence?
THanks both. Slight progress. Jim - yes, 6V to coil. I did go over the wiring again.
I've just found an old DJ body, swapped it over using the Accuspark cap and..... it started!
I see from their website that copper leads can cause interference. Could that mean it could kill the unit? I didn't know that when I bought it.
Just looked and its out of warranty. 3 miles use as its been in a box new.... I wonder if its possible to retrofit an Austin baseplate and get some decent use out of it?
No (accu) spark - test sequence? - by JonE - 26-03-2019, 03:19 PM
RE: No (accu) spark - test sequence? - by JonE - 26-03-2019, 05:41 PM
RE: No (accu) spark - test sequence? - by JonE - 26-03-2019, 09:45 PM
RE: No (accu) spark - test sequence? - by JonE - 27-03-2019, 09:57 AM
RE: No (accu) spark - test sequence? - by JonE - 27-03-2019, 10:30 PM
RE: No (accu) spark - test sequence? - by JonE - 28-03-2019, 08:58 PM
RE: No (accu) spark - test sequence? - by JonE - 02-04-2019, 10:01 PM
RE: No (accu) spark - test sequence? - by JonE - 05-04-2019, 04:31 PM
