front wheel alignment when you can't move track rod ends
Jon,
Sorry- but if I am reading this correctly you had excessive toe in- with the track rod adjusters wound down hard- surely loosening them will increase the toe in ?
This appears to show the track rod has been 'lengthened' by straightening the bends and needs resetting to original shape.
Tony.
RE: front wheel alignment when you can't move track rod ends - by Tony Press - 23-03-2019, 04:18 AM
