  • 1 Vote(s) - 4 Average
engine gearbox split
Many thanks. In the end we took the gearbox out and married it to engine on the bench. Even that was difficult enough but all done.
MN
(18-10-2017, 05:13 PM)Ruairidh Dunford Wrote: Martin,
The very best tip I have for holding the the three toggles in place was from Malcolm Parker - he suggested wedging them into the cover plate slots with thin cardboard.
You place a small strip over the slot and then push the lever down into it.  The card jams into the gaps and holds the toggle in place for fitting.
Once in use it soon dissapears without damaging anything.
That sounds like a great idea. In the end we tied them in their slots with a piece of string, almost married the gearbox and pull the string away at the last moment.
MN
engine gearbox split - by Martin Nash - 18-10-2017, 11:40 AM
RE: engine gearbox split - by Robert Leigh - 18-10-2017, 01:17 PM
RE: engine gearbox split - by Martin Nash - 18-10-2017, 01:34 PM
RE: engine gearbox split - by Derek Sheldon - 18-10-2017, 01:48 PM
RE: engine gearbox split - by Martin Prior - 18-10-2017, 04:45 PM
RE: engine gearbox split - by Ruairidh Dunford - 18-10-2017, 05:13 PM
RE: engine gearbox split - by Martin Nash - 18-10-2017, 05:50 PM
RE: engine gearbox split - by Parazine - 19-10-2017, 09:50 AM
RE: engine gearbox split - by Martin Nash - 21-10-2017, 04:53 PM
RE: engine gearbox split - by Robert Foreman - 19-10-2017, 07:29 PM
RE: engine gearbox split - by BobH - 20-10-2017, 10:36 AM
