front wheel alignment when you can't move track rod ends
Sounds as if whoever had it apart previously didn't know what they were doing. The Austin Seven handbook advocates removing the nearside steering arm having slackened the nearside trackrod end clamp and rotating the assembly the correct amount and reassembling. Setting the track to parallel works fine.
RE: front wheel alignment when you can't move track rod ends - by David Stepney - 21-03-2019, 10:44 PM
