18-10-2017, 04:45 PM
(18-10-2017, 01:48 PM)Derek Sheldon Wrote: Many people have problems with aligning the side spline with the gearbox. I personally bring the spline on the clutch to tdc, I then do the same with the gearbox in first gear, I then mark the output flange so that I can directly if it has moved. I can usually line it all up in a couple of minutes. Good luck
I use the same method as Derek and it works very well. The horrors of lining up the blind spline are really a bit of a myth. The critical trick is to have a gear engaged. I fitted, removed and re-fitted a 'box three times in quick succession at the weekend - it slid straight on every time.
