Rust pitting on flywheel
About the worst that can happen is fierceness and rapid lining wear. For the use the average Seven gets wear not likely to matter If the existing clutch plate OK would use. Quite easily changed.
However the thin metal of the disc may be seriously weakened making use a gamble.
The problem with flywheels is finding one where the taper has not been lapped.
Rust pitting on flywheel - by PhilM - 18-03-2019, 08:04 PM
RE: Rust pitting on flywheel - by AustinWood - 18-03-2019, 09:29 PM
RE: Rust pitting on flywheel - by Parazine - 18-03-2019, 10:40 PM
RE: Rust pitting on flywheel - by John Mason - 18-03-2019, 10:49 PM
RE: Rust pitting on flywheel - by PhilM - 18-03-2019, 10:56 PM
RE: Rust pitting on flywheel - by Bob Culver - 19-03-2019, 01:03 AM
RE: Rust pitting on flywheel - by Chris KC - 19-03-2019, 12:30 PM
RE: Rust pitting on flywheel - by PhilM - 20-03-2019, 07:33 PM
RE: Rust pitting on flywheel - by John Mason - 20-03-2019, 07:59 PM
RE: Rust pitting on flywheel - by Zetomagneto - 20-03-2019, 09:05 PM
RE: Rust pitting on flywheel - by Chris KC - 21-03-2019, 05:09 AM
RE: Rust pitting on flywheel - by Charles P - 21-03-2019, 11:53 AM
RE: Rust pitting on flywheel - by PhilM - 22-03-2019, 12:16 PM
