Dynamo Field Resistor
#24
There is a requirement under the Road Vehicles Lighting Regulations 1989 for cars to have a matched pair of headlamps (as related to size character positioning etc). If they do not dip then the beams should be permanently deflected downwards so as not to dazzle. ONE dipping headlamp no longer conforms because the TWO lamps should be matched (ie the same), ie two dipping or two fixed.
Dynamo Field Resistor - by David Stepney - 11-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 04:50 PM
RE: Dynamo Field Resistor - by Biddlecombe - 11-03-2019, 05:46 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:31 PM
RE: Dynamo Field Resistor - by jansens - 11-03-2019, 08:17 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 08:26 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:34 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 08:46 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:59 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 09:17 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:04 PM
RE: Dynamo Field Resistor - by Stuart Giles - 11-03-2019, 10:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:56 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 11:36 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 06:58 PM
RE: Dynamo Field Resistor - by Bill Dixon - 12-03-2019, 07:23 PM
RE: Dynamo Field Resistor - by David Stepney - 12-03-2019, 07:24 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 10:44 PM
RE: Dynamo Field Resistor - by john williams - 13-03-2019, 12:26 AM
RE: Dynamo Field Resistor - by Bob Culver - 13-03-2019, 03:33 AM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 03:56 PM
RE: Dynamo Field Resistor - by Reckless Rat - 13-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 04:43 PM
RE: Dynamo Field Resistor - by David Stepney - 20-03-2019, 08:19 PM
