  • 1 Vote(s) - 2 Average
Brake Cam Lever. cotter pins & bushes
(17-10-2017, 11:59 AM)Ruairidh Dunford Wrote: With reference to the cotter removal.  I have always found it easier to remove with the hubs complete with brake shoes and drum in place.  I have a long (2-3’) drift into the end of which I have drilled a shallow hole.  This is placed snugly over the threaded end of the cotter (with nut removed), after which a very sharp strike with a lump hammer usually sees the thing come out like a Polaris missile across the workshop floor, never to be seen again!  The length allows for ease of access in tight space and also a clean strike away from bodywork and wheels etc.  The hole prevents it slipping off.
I use the same method as Ruairidh but weld a nut of the same thread on the end of the drift. This holds everything in the correct alignment and stops the cotter flying off.
RE: Brake Cam Lever. cotter pins & bushes - by Adrian Payne - 17-10-2017, 01:05 PM
