Dynamo Field Resistor
David,
As RR says 10amps is a bit high adjust 3rd brush to 7or8amps.High power aluminum clad resistors can be found on ebay a value of 4R7 should be about right these are rated at 50watt.These can be bolted onto the bulk head to reduce the heat of the resistor,this is better than trying to wind your own resistor. Hope this helps.
Dynamo Field Resistor - by David Stepney - 11-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 04:50 PM
RE: Dynamo Field Resistor - by Biddlecombe - 11-03-2019, 05:46 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:31 PM
RE: Dynamo Field Resistor - by jansens - 11-03-2019, 08:17 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 08:26 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:34 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 08:46 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:59 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 09:17 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:04 PM
RE: Dynamo Field Resistor - by Stuart Giles - 11-03-2019, 10:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:56 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 11:36 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 06:58 PM
RE: Dynamo Field Resistor - by Bill Dixon - 12-03-2019, 07:23 PM
RE: Dynamo Field Resistor - by David Stepney - 12-03-2019, 07:24 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 10:44 PM
RE: Dynamo Field Resistor - by john williams - 13-03-2019, 12:26 AM
RE: Dynamo Field Resistor - by Bob Culver - 13-03-2019, 03:33 AM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 03:56 PM
RE: Dynamo Field Resistor - by Reckless Rat - 13-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 04:43 PM
RE: Dynamo Field Resistor - by David Stepney - 20-03-2019, 08:19 PM
