Dynamo Field Resistor
Before the field brush decided to shed its wire ( after I had washed it on Sunday and started it to put it to bed!), the dynamo charged at an indicated 10 amps, which was just enough to support the sidelamps and dipped beam ( I am on single dipping headlamps), so I think I shall leave the third brush alone. If I make up a long enough resistor coil, I can presumably find the optimum position on it to give me a suitably reduced charging rate and then trim it to length.
Dynamo Field Resistor - by David Stepney - 11-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 04:50 PM
RE: Dynamo Field Resistor - by Biddlecombe - 11-03-2019, 05:46 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:31 PM
RE: Dynamo Field Resistor - by jansens - 11-03-2019, 08:17 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 08:26 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:34 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 08:46 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:59 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 09:17 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:04 PM
RE: Dynamo Field Resistor - by Stuart Giles - 11-03-2019, 10:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:56 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 11:36 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 06:58 PM
RE: Dynamo Field Resistor - by Bill Dixon - 12-03-2019, 07:23 PM
RE: Dynamo Field Resistor - by David Stepney - 12-03-2019, 07:24 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 10:44 PM
RE: Dynamo Field Resistor - by john williams - 13-03-2019, 12:26 AM
RE: Dynamo Field Resistor - by Bob Culver - 13-03-2019, 03:33 AM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 03:56 PM
RE: Dynamo Field Resistor - by Reckless Rat - 13-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 04:43 PM
RE: Dynamo Field Resistor - by David Stepney - 20-03-2019, 08:19 PM
