Dynamo Field Resistor
About 5 or 6 ohms should be enough. I made a "Heath Robinson" one for my RP which (earlier) had a 35M dyno. Just wind some resistance wire around a pencil and fasten in between the two terminals. Leave it in the wash from the fan to keep it cool. Trial and error to get the right level but it's a cheap enough fix. Resistance wire from Maplins or the Bay of E.
Dynamo Field Resistor - by David Stepney - 11-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 04:50 PM
RE: Dynamo Field Resistor - by Biddlecombe - 11-03-2019, 05:46 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 06:22 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 06:31 PM
RE: Dynamo Field Resistor - by jansens - 11-03-2019, 08:17 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 08:26 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:34 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 08:46 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 08:59 PM
RE: Dynamo Field Resistor - by Reckless Rat - 11-03-2019, 09:17 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:04 PM
RE: Dynamo Field Resistor - by Stuart Giles - 11-03-2019, 10:22 PM
RE: Dynamo Field Resistor - by David Stepney - 11-03-2019, 10:56 PM
RE: Dynamo Field Resistor - by Bob Culver - 11-03-2019, 11:36 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 06:58 PM
RE: Dynamo Field Resistor - by Bill Dixon - 12-03-2019, 07:23 PM
RE: Dynamo Field Resistor - by David Stepney - 12-03-2019, 07:24 PM
RE: Dynamo Field Resistor - by Dave Mann - 12-03-2019, 10:44 PM
RE: Dynamo Field Resistor - by john williams - 13-03-2019, 12:26 AM
RE: Dynamo Field Resistor - by Bob Culver - 13-03-2019, 03:33 AM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 03:56 PM
RE: Dynamo Field Resistor - by Reckless Rat - 13-03-2019, 04:35 PM
RE: Dynamo Field Resistor - by David Stepney - 13-03-2019, 04:43 PM
RE: Dynamo Field Resistor - by David Stepney - 20-03-2019, 08:19 PM
