  • 2 Vote(s) - 3.5 Average
BRAKES WHAT'S NORMAL
#55
(05-03-2019, 08:06 PM)Bob Culver Wrote:  Depending on which way cotter inserted, the shank of the lever is less or more than square to the cam flat
bob - sorry, I've got to go right back to naive questions. Part of my problem may be non-standard parts so I can't interpret instructions.
The cotter would only go in from one side. So hence I thought I'd need to swap the lever from the other side to address "nuts to the back".
I noticed my cotter pins took a 10mm spanner. Is it possible that a cotter could be "wrong", if it fits and seems to work as per other cotters I have used on track rod arms and stuff?
[I remember looking through the lever cotter hole with cam in place and seeing it was completely clear through, so perhaps that's the problem if someone has altered the cam so a generic cotter is just a retainer]
This is the sight that linked to the lever being pictured in my earlier post sitting at about 4 o clock resting as looking at the rear of the backplate. With a turn of brass shim on the pivot, I am now at 5 o clock... which of course will be 4 o'c by the time the brakes apply so still rubbish.
and thanks Jim - will print this off for when next to car...
BRAKES WHAT'S NORMAL - by Paul Nott - 21-01-2019, 04:28 PM
RE: BRAKES WHAT'S NORMAL - by Martin Prior - 21-01-2019, 06:59 PM
RE: BRAKES WHAT'S NORMAL - by Reckless Rat - 21-01-2019, 07:58 PM
RE: BRAKES WHAT'S NORMAL - by Tony Betts - 21-01-2019, 08:12 PM
RE: BRAKES WHAT'S NORMAL - by Ian McGowan - 21-01-2019, 09:24 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 21-01-2019, 08:24 PM
RE: BRAKES WHAT'S NORMAL - by Hedd_Jones - 21-01-2019, 08:56 PM
RE: BRAKES WHAT'S NORMAL - by Chris KC - 21-01-2019, 09:10 PM
RE: BRAKES WHAT'S NORMAL - by Bob Kneale - 21-01-2019, 09:31 PM
RE: BRAKES WHAT'S NORMAL - by Tony Betts - 23-01-2019, 07:52 PM
RE: BRAKES WHAT'S NORMAL - by Peter Naulls - 23-01-2019, 11:19 PM
RE: BRAKES WHAT'S NORMAL - by Tony Betts - 24-01-2019, 04:27 PM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 22-01-2019, 10:13 PM
RE: BRAKES WHAT'S NORMAL - by Chris KC - 23-01-2019, 08:38 AM
RE: BRAKES WHAT'S NORMAL - by Reckless Rat - 23-01-2019, 09:06 AM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 23-01-2019, 12:31 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 23-01-2019, 08:29 PM
RE: BRAKES WHAT'S NORMAL - by Steve kay - 23-01-2019, 10:12 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 24-01-2019, 01:01 AM
RE: BRAKES WHAT'S NORMAL - by Reckless Rat - 24-01-2019, 04:49 PM
RE: BRAKES WHAT'S NORMAL - by Hedd_Jones - 24-01-2019, 04:55 PM
RE: BRAKES WHAT'S NORMAL - by Tony Betts - 24-01-2019, 07:31 PM
RE: BRAKES WHAT'S NORMAL - by Chris KC - 24-01-2019, 07:59 PM
RE: BRAKES WHAT'S NORMAL - by Peter Naulls - 25-01-2019, 12:16 AM
RE: BRAKES WHAT'S NORMAL - by JonE - 01-03-2019, 03:11 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 01-03-2019, 03:45 PM
RE: BRAKES WHAT'S NORMAL - by Timothy P - 01-03-2019, 04:30 PM
RE: BRAKES WHAT'S NORMAL - by Hedd_Jones - 01-03-2019, 04:58 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 01-03-2019, 05:59 PM
RE: BRAKES WHAT'S NORMAL - by AustinWood - 01-03-2019, 07:55 PM
RE: BRAKES WHAT'S NORMAL - by Hedd_Jones - 01-03-2019, 10:00 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 01-03-2019, 10:30 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 01-03-2019, 10:41 PM
RE: BRAKES WHAT'S NORMAL - by Hedd_Jones - 01-03-2019, 10:42 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 01-03-2019, 10:45 PM
RE: BRAKES WHAT'S NORMAL - by Timothy P - 01-03-2019, 10:50 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 02-03-2019, 09:42 AM
RE: BRAKES WHAT'S NORMAL - by Reckless Rat - 02-03-2019, 12:00 PM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 02-03-2019, 02:25 PM
RE: BRAKES WHAT'S NORMAL - by Timothy P - 02-03-2019, 04:04 PM
RE: BRAKES WHAT'S NORMAL - by Howard Wright - 02-03-2019, 06:31 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 02-03-2019, 06:43 PM
RE: BRAKES WHAT'S NORMAL - by Hedd_Jones - 02-03-2019, 07:20 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 02-03-2019, 07:33 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 02-03-2019, 07:43 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 02-03-2019, 10:16 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 02-03-2019, 10:19 PM
RE: BRAKES WHAT'S NORMAL - by Dave Mann - 04-03-2019, 09:54 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 04-03-2019, 10:07 PM
RE: BRAKES WHAT'S NORMAL - by AllAlloyCup - 05-03-2019, 01:02 PM
RE: BRAKES WHAT'S NORMAL - by Dave Mann - 05-03-2019, 06:31 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 05-03-2019, 07:09 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 05-03-2019, 08:06 PM
RE: BRAKES WHAT'S NORMAL - by AustinWood - 05-03-2019, 08:16 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 05-03-2019, 08:22 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 05-03-2019, 09:45 PM
RE: BRAKES WHAT'S NORMAL - by AustinWood - 05-03-2019, 11:33 PM
RE: BRAKES WHAT'S NORMAL - by Tony Press - 06-03-2019, 12:56 AM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 06-03-2019, 07:42 AM
RE: BRAKES WHAT'S NORMAL - by JonE - 06-03-2019, 08:45 AM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 06-03-2019, 09:14 AM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 06-03-2019, 09:18 AM
RE: BRAKES WHAT'S NORMAL - by JonE - 06-03-2019, 09:38 AM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 06-03-2019, 10:11 AM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 06-03-2019, 10:22 AM
RE: BRAKES WHAT'S NORMAL - by AustinWood - 06-03-2019, 05:21 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 06-03-2019, 05:38 PM
RE: BRAKES WHAT'S NORMAL - by Howard Wright - 06-03-2019, 08:01 PM
RE: BRAKES WHAT'S NORMAL - by AllAlloyCup - 06-03-2019, 08:11 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 06-03-2019, 08:55 PM
RE: BRAKES WHAT'S NORMAL - by AllAlloyCup - 06-03-2019, 09:13 PM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 06-03-2019, 09:17 PM
RE: BRAKES WHAT'S NORMAL - by AllAlloyCup - 06-03-2019, 09:28 PM
RE: BRAKES WHAT'S NORMAL - by AllAlloyCup - 07-03-2019, 09:14 AM
RE: BRAKES WHAT'S NORMAL - by JonE - 07-03-2019, 11:31 AM
RE: BRAKES WHAT'S NORMAL - by AustinWood - 07-03-2019, 02:29 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 07-03-2019, 03:18 PM
RE: BRAKES WHAT'S NORMAL - by AustinWood - 08-03-2019, 01:34 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 11-03-2019, 06:56 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 11-03-2019, 09:07 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 11-03-2019, 10:26 PM
RE: BRAKES WHAT'S NORMAL - by Mike Costigan - 11-03-2019, 10:34 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 11-03-2019, 10:58 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 11-03-2019, 11:25 PM
RE: BRAKES WHAT'S NORMAL - by Timothy P - 12-03-2019, 01:11 AM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 12-03-2019, 02:55 AM
RE: BRAKES WHAT'S NORMAL - by Ruairidh Dunford - 12-03-2019, 09:15 AM
RE: BRAKES WHAT'S NORMAL - by JonE - 12-03-2019, 09:40 AM
RE: BRAKES WHAT'S NORMAL - by Timothy P - 12-03-2019, 06:44 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 12-03-2019, 09:38 PM
RE: BRAKES WHAT'S NORMAL - by Timothy P - 12-03-2019, 10:21 PM
RE: BRAKES WHAT'S NORMAL - by Dave Mann - 12-03-2019, 10:52 PM
RE: BRAKES WHAT'S NORMAL - by Paul Nott - 12-03-2019, 11:56 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 13-03-2019, 12:09 AM
RE: BRAKES WHAT'S NORMAL - by JonE - 13-03-2019, 09:25 AM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 13-03-2019, 09:43 AM
RE: BRAKES WHAT'S NORMAL - by AustinWood - 13-03-2019, 06:55 PM
RE: BRAKES WHAT'S NORMAL - by Paul Nott - 14-03-2019, 05:50 PM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 15-03-2019, 07:41 PM
RE: BRAKES WHAT'S NORMAL - by Reckless Rat - 15-03-2019, 08:05 PM
RE: BRAKES WHAT'S NORMAL - by bob46320 - 16-03-2019, 08:24 AM
RE: BRAKES WHAT'S NORMAL - by Paul Nott - 16-03-2019, 04:05 PM
RE: BRAKES WHAT'S NORMAL - by "Slack Alice" Simon - 16-03-2019, 05:44 PM
RE: BRAKES WHAT'S NORMAL - by JonE - 23-03-2019, 09:05 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 23-03-2019, 09:40 PM
RE: BRAKES WHAT'S NORMAL - by Peter Clayton - 27-03-2019, 08:38 PM
RE: BRAKES WHAT'S NORMAL - by Bob Culver - 27-03-2019, 09:16 PM
