Cracked cylinder block
I have just skimmed a few thou off the top of my best of three blocks that I have, standard bore, good valve seats etc.
Unfortunately the cast iron dust collected on the bore between 2 and 3 cylinders and highlighted what appears to be a crack. The cracks are on adjacent sides of each bore.
Does this mean it’s scrap or is it ok to use, or can it be sleeved and used?
Roger
Cracked cylinder block - by Roger - 05-03-2019, 01:55 PM
RE: Cracked cylinder block - by Zetomagneto - 05-03-2019, 02:46 PM
RE: Cracked cylinder block - by Roger - 05-03-2019, 07:57 PM
RE: Cracked cylinder block - by Colin Reed - 05-03-2019, 08:41 PM
RE: Cracked cylinder block - by Roger - 05-03-2019, 09:24 PM
RE: Cracked cylinder block - by Colin Reed - 05-03-2019, 09:34 PM
RE: Cracked cylinder block - by Roger - 05-03-2019, 09:36 PM
