bantam turbo
#21
Can't see why 5 lb or so of boost would cause problems with the block-crankcase joint; we ran 8.5 lb of boost on an A7 racecar for several seasons without any issues with that joint. I'm not sure I would run such a fine filter as 70 microns on the suck side of the oil pump though; something a bit more like a tea strainer on the inlet side would be all that's necessary to protect the pump along with a conventional full flow filter on the outlet side.
bantam turbo - by steve anderson - 01-03-2019, 06:44 AM
RE: bantam turbo - by Colin Reed - 01-03-2019, 08:59 AM
RE: bantam turbo - by Edgar Lowe - 01-03-2019, 12:10 PM
RE: bantam turbo - by squeak - 01-03-2019, 12:32 PM
RE: bantam turbo - by Timothy P - 01-03-2019, 01:03 PM
RE: bantam turbo - by Hedd_Jones - 01-03-2019, 02:10 PM
RE: bantam turbo - by Zetomagneto - 01-03-2019, 08:18 PM
RE: bantam turbo - by Colin Reed - 01-03-2019, 08:44 PM
RE: bantam turbo - by stuartu - 01-03-2019, 09:24 PM
RE: bantam turbo - by Zetomagneto - 01-03-2019, 09:30 PM
RE: bantam turbo - by Hedd_Jones - 01-03-2019, 09:48 PM
RE: bantam turbo - by Zetomagneto - 01-03-2019, 09:59 PM
RE: bantam turbo - by Hedd_Jones - 01-03-2019, 10:11 PM
RE: bantam turbo - by Zetomagneto - 01-03-2019, 10:45 PM
RE: bantam turbo - by Alan - 01-03-2019, 11:25 PM
RE: bantam turbo - by Hedd_Jones - 01-03-2019, 11:47 PM
RE: bantam turbo - by steve anderson - 02-03-2019, 08:10 AM
RE: bantam turbo - by Steve kay - 02-03-2019, 08:55 AM
RE: bantam turbo - by jansens - 02-03-2019, 08:20 PM
RE: bantam turbo - by stuartu - 03-03-2019, 09:11 AM
RE: bantam turbo - by Stuart Giles - 03-03-2019, 09:34 PM
RE: bantam turbo - by Boaty - 10-03-2019, 08:48 AM
RE: bantam turbo - by Alan - 10-03-2019, 01:51 PM
RE: bantam turbo - by steve anderson - 04-01-2020, 04:18 AM
RE: bantam turbo - by Chris KC - 04-01-2020, 09:12 AM
