03-03-2019, 03:05 PM
I definitely wouldn’t start the engine with loose cover plate, it’s not spring pressure holding the clutch
so no point in slackening the bolts and then starting it.
Try previous suggestions re starting it in gear and driving with the clutch pedal depressed you will find it will come free.You could also prod the throttle while driving to put some shock loading into it.
