Oil on rear brakes
It is the half shaft nut, so will only cure the leak if oil is finding its way along between the axle taper and rear hub.The larger nut covers a greater area of the outer face of the hub, in other words the larger nut is larger when measured across the flats.Will only cure the leak if that's where the oil is coming from!
Oil on rear brakes - by Nick Salmon - 12-10-2017, 08:27 AM
RE: Oil on rear brakes - by Zetomagneto - 12-10-2017, 08:40 AM
RE: Oil on rear brakes - by Derek Sheldon - 12-10-2017, 08:54 AM
RE: Oil on rear brakes - by Bob Culver - 14-10-2017, 05:05 AM
RE: Oil on rear brakes - by Steve Berg - 14-10-2017, 11:26 AM
RE: Oil on rear brakes - by Bob Culver - 14-10-2017, 10:13 PM
RE: Oil on rear brakes - by Parazine - 17-10-2017, 11:31 AM
RE: Oil on rear brakes - by Ruairidh Dunford - 17-10-2017, 11:37 AM
