  • 2 Vote(s) - 3.5 Average
Rear Main Bearings
#37
Only an opinion Ruairidh but I think you are right, C3 are used where there is a risk that thermal expansion will close up the bearing clearance. I don't think this applies to A7's by any stretch of the imagination.
Possible arguments for using one?
Unusually tight fit on the shaft can close up bearing clearance slightly - but in that case you'd do better to rectify the shaft if needed (in the case of A7 rear main I believe a tight fit is a good thing).
Crankshaft whip - more slack in the bearing may accommodate a bit of deflection. But this is loading the rollers the wrong way and doesn't seem a good plan to me.
Or that you simply can't get anything else - in which case I'd use one!
Rear Main Bearings - by David Stepney - 19-02-2019, 09:50 PM
RE: Rear Main Bearings - by Chris KC - 19-02-2019, 10:38 PM
RE: Rear Main Bearings - by David Stepney - 19-02-2019, 10:47 PM
RE: Rear Main Bearings - by David Witton - 19-02-2019, 11:33 PM
RE: Rear Main Bearings - by David Stepney - 20-02-2019, 12:49 AM
RE: Rear Main Bearings - by Colin Reed - 20-02-2019, 01:33 AM
RE: Rear Main Bearings - by Tony Press - 20-02-2019, 04:27 AM
RE: Rear Main Bearings - by Matt_Harnden - 20-02-2019, 08:01 AM
RE: Rear Main Bearings - by Bob Culver - 20-02-2019, 08:31 AM
RE: Rear Main Bearings - by Colin Reed - 20-02-2019, 08:48 AM
RE: Rear Main Bearings - by squeak - 20-02-2019, 08:55 AM
RE: Rear Main Bearings - by Ruairidh Dunford - 20-02-2019, 09:06 AM
RE: Rear Main Bearings - by David Stepney - 20-02-2019, 10:11 AM
RE: Rear Main Bearings - by Colin Reed - 20-02-2019, 10:24 AM
RE: Rear Main Bearings - by Ruairidh Dunford - 20-02-2019, 10:55 AM
RE: Rear Main Bearings - by Chris KC - 20-02-2019, 02:25 PM
RE: Rear Main Bearings - by Zetomagneto - 20-02-2019, 09:24 PM
RE: Rear Main Bearings - by Bob Culver - 20-02-2019, 09:33 PM
RE: Rear Main Bearings - by Zetomagneto - 20-02-2019, 09:37 PM
RE: Rear Main Bearings - by Tom the Blacksmith - 20-02-2019, 09:48 PM
RE: Rear Main Bearings - by Jeff Taylor - 20-02-2019, 10:33 PM
RE: Rear Main Bearings - by Chris KC - 20-02-2019, 11:34 PM
RE: Rear Main Bearings - by David Stepney - 21-02-2019, 12:27 AM
RE: Rear Main Bearings - by Tony Press - 21-02-2019, 12:54 AM
RE: Rear Main Bearings - by David Stepney - 21-02-2019, 01:04 AM
RE: Rear Main Bearings - by Tony Press - 21-02-2019, 01:08 AM
RE: Rear Main Bearings - by Bob Culver - 21-02-2019, 03:40 AM
RE: Rear Main Bearings - by Ruairidh Dunford - 21-02-2019, 08:54 AM
RE: Rear Main Bearings - by squeak - 21-02-2019, 10:46 AM
RE: Rear Main Bearings - by Chris KC - 21-02-2019, 12:59 PM
RE: Rear Main Bearings - by Zetomagneto - 21-02-2019, 10:57 PM
RE: Rear Main Bearings - by Chris KC - 21-02-2019, 11:37 PM
RE: Rear Main Bearings - by Zetomagneto - 21-02-2019, 11:41 PM
RE: Rear Main Bearings - by Bob Culver - 22-02-2019, 12:37 AM
RE: Rear Main Bearings - by Tony Press - 22-02-2019, 12:55 AM
RE: Rear Main Bearings - by Ruairidh Dunford - 22-02-2019, 09:20 AM
RE: Rear Main Bearings - by Chris KC - 22-02-2019, 09:45 AM
RE: Rear Main Bearings - by Dave Wortley - 22-02-2019, 12:54 PM
RE: Rear Main Bearings - by Bob Culver - 22-02-2019, 07:34 PM
RE: Rear Main Bearings - by David Stepney - 24-02-2019, 08:42 PM
RE: Rear Main Bearings - by Ruairidh Dunford - 24-02-2019, 08:54 PM
RE: Rear Main Bearings - by David Stepney - 24-02-2019, 09:17 PM
RE: Rear Main Bearings - by Ruairidh Dunford - 24-02-2019, 09:25 PM
RE: Rear Main Bearings - by Chris KC - 24-02-2019, 10:33 PM
RE: Rear Main Bearings - by Bob Culver - 24-02-2019, 10:57 PM
RE: Rear Main Bearings - by David Stepney - 25-02-2019, 09:21 AM
RE: Rear Main Bearings - by Hedd_Jones - 25-02-2019, 10:28 AM
RE: Rear Main Bearings - by Bob Culver - 25-02-2019, 10:52 AM
RE: Rear Main Bearings - by Ken Morton - 25-02-2019, 08:31 PM
RE: Rear Main Bearings - by David Stepney - 25-02-2019, 09:57 PM
RE: Rear Main Bearings - by Hedd_Jones - 25-02-2019, 10:28 PM
RE: Rear Main Bearings - by David Stepney - 25-02-2019, 11:04 PM
RE: Rear Main Bearings - by Tony Press - 26-02-2019, 01:18 AM
RE: Rear Main Bearings - by Mark McKibbin - 26-02-2019, 01:08 PM
RE: Rear Main Bearings - by Bob Culver - 27-02-2019, 11:17 PM
RE: Rear Main Bearings - by David Stepney - 28-02-2019, 12:27 AM
RE: Rear Main Bearings - by David Stepney - 29-04-2019, 07:47 PM
RE: Rear Main Bearings - by Ruairidh Dunford - 29-04-2019, 07:57 PM
RE: Rear Main Bearings - by Chris KC - 29-04-2019, 08:16 PM
RE: Rear Main Bearings - by David Stepney - 29-04-2019, 08:38 PM
RE: Rear Main Bearings - by Tony Press - 29-04-2019, 11:11 PM
