Pressurized fuel tank
I run a pressurized tank in the supercharged single seater, I had to install a one way valve in the line to ensure that the tank remained under pressure as it was bleeding back through the pump.
2 to 3lbs is more than sufficient, if you pump it up too hard it'll just overcome the needle and seat an you will flood the carb.
One or two pumps down the main straight is enough to get all the way round the track even with the blower feeding the oily bits. You will need a tank cap that seals tightly.
Aye
Greig
Pressurized fuel tank - by Scarlet O'Hara - 21-02-2019, 05:40 PM
RE: Pressurized fuel tank - by Erich - 21-02-2019, 07:07 PM
RE: Pressurized fuel tank - by Greig Smith - 21-02-2019, 07:10 PM
RE: Pressurized fuel tank - by Tom the Blacksmith - 21-02-2019, 08:06 PM
RE: Pressurized fuel tank - by Robert Foreman - 21-02-2019, 08:08 PM
RE: Pressurized fuel tank - by Scarlet O'Hara - 22-02-2019, 01:57 PM
RE: Pressurized fuel tank - by Greig Smith - 22-02-2019, 02:58 PM
RE: Pressurized fuel tank - by Robert Foreman - 22-02-2019, 08:55 PM
RE: Pressurized fuel tank - by Scarlet O'Hara - 23-02-2019, 07:07 PM
RE: Pressurized fuel tank - by Greig Smith - 24-02-2019, 03:11 PM
RE: Pressurized fuel tank - by Scarlet O'Hara - 26-02-2019, 11:05 AM
