Compression test?
Hi, it's helpful to hear what has been said about cylinder compressions as my 1937 Ruby has pressures of between 85 & 95psi and I was wondering if it was a bit on the low side because I recall testing an old 1960's Mini and getting 140psi plus!! If you squirt engine oil into the cylinder before taking the pressure and you get a higher reading it could indicate bore wear. Would that be a fair assumption?
Compression test? - by Graham Honnor - 09-10-2017, 12:11 PM
RE: Compression test? - by Martin Prior - 09-10-2017, 12:21 PM
RE: Compression test? - by Graham Honnor - 09-10-2017, 12:28 PM
RE: Compression test? - by Bob Culver - 10-10-2017, 06:00 AM
RE: Compression test? - by Chris KC - 10-10-2017, 06:36 PM
RE: Compression test? - by Derek Simmons - 11-10-2017, 03:55 PM
RE: Compression test? - by Chris KC - 11-10-2017, 06:45 PM
RE: Compression test? - by Graham Honnor - 11-10-2017, 07:09 PM
RE: Compression test? - by stevenm - 13-01-2020, 07:32 PM
RE: Compression test? - by bob46320 - 13-01-2020, 08:06 PM
RE: Compression test? - by dickie65 - 13-01-2020, 09:08 PM
RE: Compression test? - by stevenm - 14-01-2020, 10:44 AM
RE: Compression test? - by Chris KC - 14-01-2020, 11:02 AM
RE: Compression test? - by stevenm - 14-01-2020, 12:56 PM
RE: Compression test? - by Nick Turley - 14-01-2020, 07:14 PM
RE: Compression test? - by Bob Culver - 14-01-2020, 08:49 PM
RE: Compression test? - by John Mason - 14-01-2020, 09:44 PM
RE: Compression test? - by stevenm - 15-01-2020, 10:53 AM
RE: Compression test? - by Bob Culver - 15-01-2020, 07:51 PM
RE: Compression test? - by stevenm - 16-01-2020, 12:42 PM
RE: Compression test? - by AustinWood - 16-01-2020, 02:38 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 07:26 PM
RE: Compression test? - by stevenm - 16-01-2020, 09:15 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 09:36 PM
RE: Compression test? - by Alan - 16-01-2020, 09:48 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 10:25 PM
RE: Compression test? - by Tony Press - 17-01-2020, 02:26 AM
