Pressure Fed Conversion
Hi Charles,
Vintage engine rather than PVT I take it. Mag engine ?
I suspect your build is like my current engine 1934.
It is still worth putting a metering orfice into the camshaft feed and either making a new bearing without the oil groove or tinning it and filling it with solder, oil will still find its way to the cam drive gears.
I have made a brass reducing bush which is an interference fit it has a 1.5 mm drilling for the oil feed to the camshaft.
If you look inside the camshaft bearing housing on a lot of crankcases you will see where the oil has scoured the alloy away from the oil feed drilling.
The external O rings stop oil from going round the outside of the camshaft bearing ( I suspect you will still have oil at about 60 to 80 PSI )
What feed are you using to the crankshaft nose ?
Brass bush type or lip seal type ?
The brass bush type will help feed oil to the timing cover and lubricate the gears.
Pressure Fed Conversion - by Charles P - 18-02-2019, 03:15 PM
RE: Pressure Fed Conversion - by Robert Leigh - 18-02-2019, 04:20 PM
RE: Pressure Fed Conversion - by Chris KC - 18-02-2019, 05:21 PM
RE: Pressure Fed Conversion - by jansens - 18-02-2019, 05:42 PM
RE: Pressure Fed Conversion - by Charles P - 18-02-2019, 06:02 PM
RE: Pressure Fed Conversion - by Chris KC - 18-02-2019, 07:10 PM
RE: Pressure Fed Conversion - by Robert Leigh - 18-02-2019, 07:18 PM
RE: Pressure Fed Conversion - by Chris KC - 18-02-2019, 07:24 PM
RE: Pressure Fed Conversion - by dickie65 - 18-02-2019, 07:53 PM
RE: Pressure Fed Conversion - by Steve Jones - 18-02-2019, 07:57 PM
RE: Pressure Fed Conversion - by Chris KC - 18-02-2019, 08:02 PM
RE: Pressure Fed Conversion - by Charles P - 18-02-2019, 08:48 PM
RE: Pressure Fed Conversion - by dickie65 - 18-02-2019, 09:26 PM
RE: Pressure Fed Conversion - by stuartu - 18-02-2019, 09:59 PM
RE: Pressure Fed Conversion - by dickie65 - 18-02-2019, 10:26 PM
RE: Pressure Fed Conversion - by jansens - 18-02-2019, 10:34 PM
RE: Pressure Fed Conversion - by Charles P - 18-02-2019, 11:23 PM
RE: Pressure Fed Conversion - by Chris KC - 18-02-2019, 11:42 PM
RE: Pressure Fed Conversion - by squeak - 15-02-2023, 02:52 PM
RE: Pressure Fed Conversion - by Terrytuned - 16-02-2023, 12:41 PM
RE: Pressure Fed Conversion - by squeak - 17-02-2023, 12:33 AM
RE: Pressure Fed Conversion - by dickie65 - 23-02-2023, 07:26 PM
RE: Pressure Fed Conversion - by squeak - 24-02-2023, 02:20 AM
RE: Pressure Fed Conversion - by Terrytuned - 24-02-2023, 11:37 AM
RE: Pressure Fed Conversion - by squeak - 24-02-2023, 12:54 PM
