REAR HUB NUT SIZE
The nut does not have to be absurdly tight (the end of the axle is remarkably thin. The old style F adjustable spanners are very useful for this and many household plumbing jobs. Open wide, fit in where a Crescent type will not, and Crescent type were/are expensive. Every old man’s workshop and swapmeet has. Usually strained but can coax the jaws back to parallel with a hammer and file. Not so precious that cannot be tightend with a few gentle hammer blows.
Diabolical though they may be, pipe wrenches have their uses. I have encountered garage maintained cars with drain plugs completely rounded off; a pipe wrench can avoid laborious filing of  new flats.
There are several nuts on Sevens large for the typical old time owners tool kit. Many have attracted attentionn using a blunt (or not) punch
For the rest of the original question rear hubs,  rear axles, tapers, sealed bearings, substitute seals, all been extensively covered and Search should produce. The direction of the cam cotters influences lever angle.
REAR HUB NUT SIZE - by Paul Nott - 10-02-2019, 10:13 AM
RE: REAR HUB NUT SIZE - by David Cochrane - 12-02-2019, 11:25 AM
RE: REAR HUB NUT SIZE - by Tony Betts - 12-02-2019, 01:20 PM
RE: REAR HUB NUT SIZE - by Tony Press - 12-02-2019, 10:18 PM
RE: REAR HUB NUT SIZE - by Ruairidh Dunford - 12-02-2019, 10:28 PM
RE: REAR HUB NUT SIZE - by Bob Culver - 12-02-2019, 11:29 PM
RE: REAR HUB NUT SIZE - by JonE - 28-02-2022, 01:30 PM
RE: REAR HUB NUT SIZE - by Hugh Barnes - 28-02-2022, 02:47 PM
RE: REAR HUB NUT SIZE - by Stuart Giles - 28-02-2022, 02:52 PM
RE: REAR HUB NUT SIZE - by JonE - 28-02-2022, 03:31 PM
RE: REAR HUB NUT SIZE - by Hedd_Jones - 01-03-2022, 12:25 PM
