Ruby Mk1/Mk2 Front Wheel Arch Differences
It may be that the LH wing is high and the RH wing is low - if I rotate the curved panel below the grille (it must have proper name?!)  round a bit maybe that will allow the wings to look more level.
Could also be a bent wing stay - even with the headlamp wiggled into the righ place it's still not as high as the LH lamp The RH wing has clearly had a hard life as there's a lot of 60/70s filler all over it. Maybe a RHF accident at some point bent it all and it's been pulled back into shape and filled.
....or perhaps the front end wonkiness is part of Burt's charm!
(btw that's a photo from the day we extracted him from 29years of hibernation)
RE: Ruby Mk1/Mk2 Front Wheel Arch Differences - by fatcatvera - 12-02-2019, 11:25 AM
