09-10-2017, 04:43 PM
The Brooklands body had a box section along the full length. This had a long teardrop shape aperture through which the axle tubes projected. The body was fixed to the chassis crossmembers by brackets located at the front of the box section, and at the front end of the teardrop hole. There was no support for the rear of the body other than from the rear crossmember. The body frame is however very rigid if correctly made.
