Compression test?
(09-10-2017, 12:11 PM)Graham Honnor Wrote: Hello All
I have recently carried out a compression test on my vehicle for no other reason than curiosity and wondered
if somebody would be kind enough to analyse the results for me please.
The engine is a '37 Ruby M2443** 2 bearing and I did the test on a cold engine.
Cylinders 1 - 4    80, 83, 85, 80  respectively.
As I said, I am only curious as to whether these results are in the right field because the car is running fine.
Many thanks for your time.
Graham.
My RP, with over 80,000 miles since its last rebore, gives readings of around 82 - 86 psi and the PD, with perhaps 20,000 miles, 88 - 92 psi.
Compression test? - by Graham Honnor - 09-10-2017, 12:11 PM
RE: Compression test? - by Martin Prior - 09-10-2017, 12:21 PM
RE: Compression test? - by Graham Honnor - 09-10-2017, 12:28 PM
RE: Compression test? - by Bob Culver - 10-10-2017, 06:00 AM
RE: Compression test? - by Chris KC - 10-10-2017, 06:36 PM
RE: Compression test? - by Derek Simmons - 11-10-2017, 03:55 PM
RE: Compression test? - by Chris KC - 11-10-2017, 06:45 PM
RE: Compression test? - by Graham Honnor - 11-10-2017, 07:09 PM
RE: Compression test? - by stevenm - 13-01-2020, 07:32 PM
RE: Compression test? - by bob46320 - 13-01-2020, 08:06 PM
RE: Compression test? - by dickie65 - 13-01-2020, 09:08 PM
RE: Compression test? - by stevenm - 14-01-2020, 10:44 AM
RE: Compression test? - by Chris KC - 14-01-2020, 11:02 AM
RE: Compression test? - by stevenm - 14-01-2020, 12:56 PM
RE: Compression test? - by Nick Turley - 14-01-2020, 07:14 PM
RE: Compression test? - by Bob Culver - 14-01-2020, 08:49 PM
RE: Compression test? - by John Mason - 14-01-2020, 09:44 PM
RE: Compression test? - by stevenm - 15-01-2020, 10:53 AM
RE: Compression test? - by Bob Culver - 15-01-2020, 07:51 PM
RE: Compression test? - by stevenm - 16-01-2020, 12:42 PM
RE: Compression test? - by AustinWood - 16-01-2020, 02:38 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 07:26 PM
RE: Compression test? - by stevenm - 16-01-2020, 09:15 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 09:36 PM
RE: Compression test? - by Alan - 16-01-2020, 09:48 PM
RE: Compression test? - by Colin Wilks - 16-01-2020, 10:25 PM
RE: Compression test? - by Tony Press - 17-01-2020, 02:26 AM
