06-02-2019, 03:07 PM
Bad luck, here are photos of my gearbox, dragged it off the car especially!!!
The gearbox is not right for my car as it has the coupled brakes, but at some time circa early 1950's, the engine was replaced (from a 1930 to a 1929 unit) and I guess the transmission was swapped over at the same time, got no idea how good or bad the gears are! I haven't started on the strip down as yet.
[attachment=5302]
Here is the stop, I don't know if this is complete or has been cut down, the height is about 15mm
[attachment=5303]
Here is the overall length
[attachment=5304]
And a close-up to accurately read the dimension, like I said, I don't know if this has been cut down or not, I believe that H-Sevens may have a decent part, they had one advertised on eBay a few months ago that did not sell.
Presumably, your gearbox casing does not have the boss for the metal tang to screw into, you need my gearbox casing!!!
Hope that helps.
[attachment=5302]
[attachment=5303]
[attachment=5304]
Hope that helps.
