Ruby engine removal?
After years of lining up the clutch master spline with the gearbox bell housing wobbling on the short crankcase studs, I came up with the following:-
make a couple of long (6" or so) studs to fit to the top crankcase stud locations, to provide 'guide rails' on which to slide the gearbox assembly on to the engine. With top gear engaged it takes only a minute or so to get the clutch to slide into engagement. I don't bother with the centering tool - assemble the clutch cover loosely and you have enough wiggle room to get it correctly centred, and then you carefully tighten the cover, and lock the tabs. The long studs can be removed and the originals refitted.
Haven't tried it with the engine in the car - slightly shorter studs may be necessary.
Hope to be able to attach an image.
Good luck
Bob
    try this attempt!
Ruby engine removal? - by Darren D - 05-02-2019, 11:34 AM
RE: Ruby engine removal? - by Chris KC - 05-02-2019, 01:03 PM
RE: Ruby engine removal? - by Darren D - 05-02-2019, 05:59 PM
RE: Ruby engine removal? - by Nick Salmon - 05-02-2019, 01:26 PM
RE: Ruby engine removal? - by Charles Levien - 05-02-2019, 01:31 PM
RE: Ruby engine removal? - by Chris KC - 05-02-2019, 01:37 PM
RE: Ruby engine removal? - by Nick Salmon - 05-02-2019, 01:40 PM
RE: Ruby engine removal? - by Derek Sheldon - 05-02-2019, 03:52 PM
RE: Ruby engine removal? - by Charles Levien - 05-02-2019, 04:09 PM
RE: Ruby engine removal? - by e-richard - 05-02-2019, 03:58 PM
RE: Ruby engine removal? - by Hugh Barnes - 05-02-2019, 04:25 PM
RE: Ruby engine removal? - by Charles Levien - 05-02-2019, 06:16 PM
RE: Ruby engine removal? - by Derek Sheldon - 05-02-2019, 04:28 PM
RE: Ruby engine removal? - by John Mason - 05-02-2019, 05:00 PM
RE: Ruby engine removal? - by Chris KC - 05-02-2019, 07:03 PM
RE: Ruby engine removal? - by dickie65 - 05-02-2019, 07:06 PM
RE: Ruby engine removal? - by Chris KC - 05-02-2019, 07:33 PM
RE: Ruby engine removal? - by Bob Kneale - 05-02-2019, 11:13 PM
RE: Ruby engine removal? - by Steve kay - 06-02-2019, 11:22 AM
RE: Ruby engine removal? - by AustinWood - 06-02-2019, 08:35 AM
RE: Ruby engine removal? - by dickie65 - 07-02-2019, 11:21 PM
RE: Ruby engine removal? - by jansens - 08-02-2019, 12:29 AM
RE: Ruby engine removal? - by Denis Sweeney - 02-12-2022, 09:33 PM
RE: Ruby engine removal? - by Bluebird7 - 02-12-2022, 09:41 PM
RE: Ruby engine removal? - by John Mason - 02-12-2022, 09:47 PM
RE: Ruby engine removal? - by Ruairidh Dunford - 02-12-2022, 09:50 PM
RE: Ruby engine removal? - by Denis Sweeney - 02-12-2022, 09:52 PM
