SU 1" - difference between jets?
Thanks for the advice. Things are looking much better now - car runs and does not cut out. It now starts without any choke and have the feeling it is still an over rich mixture but much improved. Have tried screwing up the mixture nut but with little change. I am unsure if the needle valve in the float chamber should be adjusted ie is the level there too high? There is no spring on the piston and the piston drops quickly when the throttle is released. Should the dashpot have oil? So a couple of issues still, but feel I am getting close.
SU 1" - difference between jets? - by JonE - 02-01-2019, 11:05 PM
RE: SU 1" - difference between jets? - by JonE - 03-01-2019, 11:29 AM
RE: SU 1" - difference between jets? - by JonE - 03-01-2019, 05:29 PM
RE: SU 1" - difference between jets? - by garryruck - 26-01-2019, 08:31 PM
