SU 1" - difference between jets?
Sorry to give a different slant to this topic but I have an SU carb on a high compression headed in a 19 29 fabric bodied saloonwhich floods badly to the point of causing the engine to stop. Once it sits for a while it starts again but floods to a stop again. There is no spring or damper in the carb - just a simple brass screw in cap with a screwdriver slot (not knurled). Question is should there be a spring or a damper. It has an electric fuel pump but the float in the bowl works fine as after a couple of clicks the pump stops prior to starting. Any answers as to spring and damper much appreciated.
SU 1" - difference between jets? - by JonE - 02-01-2019, 11:05 PM
RE: SU 1" - difference between jets? - by JonE - 03-01-2019, 11:29 AM
RE: SU 1" - difference between jets? - by JonE - 03-01-2019, 05:29 PM
RE: SU 1" - difference between jets? - by garryruck - 24-01-2019, 10:16 PM
