Chummy engine mounts?
(23-01-2019, 12:43 PM)jboy964 Wrote:
(23-01-2019, 11:56 AM)Davemayle Wrote: Hi John, I put mine on the special.
Thanks Dave, that’s what I had in mind.
John
I can’t see the point of putting a rubber under the crankcase foot, it will not insulate noise because the bolt will still in contact at the top, and within the mounting hole.
On the later rubber mounted crankcase you have 3 rubbers, top, bottom, and inner so the bolt does not
contact the crankcase.Also, as suggested by Bob you are likely to upset alignment around the starting handle nose
Chummy engine mounts? - by jboy964 - 22-01-2019, 05:11 PM
RE: Chummy engine mounts? - by Dave Wortley - 22-01-2019, 07:51 PM
RE: Chummy engine mounts? - by Bob Culver - 22-01-2019, 07:56 PM
RE: Chummy engine mounts? - by Bill Sheehan - 22-01-2019, 11:57 PM
RE: Chummy engine mounts? - by David.H - 23-01-2019, 10:57 AM
RE: Chummy engine mounts? - by jboy964 - 23-01-2019, 11:02 AM
RE: Chummy engine mounts? - by Nick Turley - 23-01-2019, 12:24 AM
RE: Chummy engine mounts? - by Bob Culver - 23-01-2019, 01:14 AM
RE: Chummy engine mounts? - by Davemayle - 23-01-2019, 11:56 AM
RE: Chummy engine mounts? - by jboy964 - 23-01-2019, 12:43 PM
RE: Chummy engine mounts? - by Zetomagneto - 23-01-2019, 09:52 PM
RE: Chummy engine mounts? - by Bill Sheehan - 24-01-2019, 12:16 AM
RE: Chummy engine mounts? - by andrew34ruby - 23-01-2019, 12:13 PM
RE: Chummy engine mounts? - by jansens - 24-01-2019, 09:31 AM
RE: Chummy engine mounts? - by AustinWood - 24-01-2019, 11:13 AM
