Diff casing breather pipe?
how much oil did you use for fill? I was advised to cut the recommended amount down considerably for old axles that might leak through old solidifed seals... but that one needs to check/replace often if taking this route.
Diff casing breather pipe? - by Biddlecombe - 20-01-2019, 11:12 AM
RE: Diff casing breather pipe? - by bob46320 - 20-01-2019, 11:28 AM
RE: Diff casing breather pipe? - by Biddlecombe - 20-01-2019, 11:38 AM
RE: Diff casing breather pipe? - by Tony Press - 20-01-2019, 11:11 PM
RE: Diff casing breather pipe? - by Colin Wilks - 21-01-2019, 01:07 PM
RE: Diff casing breather pipe? - by JonE - 21-01-2019, 03:21 PM
RE: Diff casing breather pipe? - by Biddlecombe - 21-01-2019, 03:33 PM
