A7 HAND CONTROL TUBES
I recently acquired a pair of control tubes, as the inner one on the column from The Thing from the Cesspit (1933 RP) is broken.
Having cleaned them up, I then realised that replacements are both shorter - outer tube 29 3/4" against 32 3/4" - and a smaller diameter - 1/2" against 9/16" - than the 1933 item.
Can anyone confirm whether the replacements are from an earlier A7? If they are, I'd be happy to swap or p/x them for a later set.
My next problem is to extract the tube from the steering box - it feels like it's been welded in!
A7 HAND CONTROL TUBES - by Martin Prior - 20-01-2019, 08:28 PM
RE: A7 HAND CONTROL TUBES - by Hedd_Jones - 20-01-2019, 08:44 PM
RE: A7 HAND CONTROL TUBES - by Tony Betts - 20-01-2019, 09:02 PM
RE: A7 HAND CONTROL TUBES - by Tony Press - 20-01-2019, 11:06 PM
