Ulster/EA Sports build
Hi Arthur, Fitting a Reliant engine will involve a bit of chopping thingsĀ around on a standard body, there are a couple of ways to fit the Reliant engine, it can be fitted sitting forward and high on top of the chassis and use the standard Ruby prop shaft or further back and between the chassis rails. I would suggest you have a test fitting of the engine and box on the rollingĀ chassis, with all the components you will be using, steering box and so on in place, choose the setup you like the most, take a few measurements and have a word with Mr Yates to build your floor pan/ bulkhead to suite the chassis set up if that is possible.
Ulster/EA Sports build - by merlinart - 03-10-2017, 07:33 PM
RE: Ulster/EA Sports build - by Phil Kingdom - 03-10-2017, 11:07 PM
RE: Ulster/EA Sports build - by Malcolm Parker - 04-10-2017, 10:55 AM
RE: Ulster/EA Sports build - by merlinart - 04-10-2017, 06:34 PM
RE: Ulster/EA Sports build - by Alan - 04-10-2017, 07:03 PM
RE: Ulster/EA Sports build - by merlinart - 05-10-2017, 09:43 AM
RE: Ulster/EA Sports build - by Phil Kingdom - 04-10-2017, 07:35 PM
RE: Ulster/EA Sports build - by Ruairidh Dunford - 05-10-2017, 10:09 AM
RE: Ulster/EA Sports build - by merlinart - 05-10-2017, 01:15 PM
RE: Ulster/EA Sports build - by Phil Kingdom - 05-10-2017, 11:04 PM
RE: Ulster/EA Sports build - by merlinart - 06-10-2017, 09:13 AM
RE: Ulster/EA Sports build - by Phil Kingdom - 06-10-2017, 12:10 PM
